Old 12-Feb-2012, 6:07 AM   #9
Tv antennas and Tv reception
Ok after doing more research then a sane person would. Here is my recommendation. Most of the tv signals are very weak. Install this antenna mount on the high roof part of the house , http://www.ronard.com/Tripods%200703/4712.html. And instal a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp and will be connected to one tv that has a Digital Broadcast Tv Tuner. The antenna will be turned aimed at the two groups of tv stations. One group at 81 degree magnetic compass is a weak signal strength group and has these tv stations channels , WBRE-DT 11 NBC , WYOU-DT 13 CBS , WNEP-TV 50 ABC and Antenna Tv , WOLF-DT 45 FOX and The CW and MyNetwork.
