Tv antennas and Tv reception
The ANT751 has a wide forward beam width ( angle of reception ) to the left and right of the antenna. The ANT751 is aimed in between the groups of stations for reception of both groups of stations. The preamp will raise the signal strength and push the signal through the coax to the tv. Turn the antenna to the left and right for the best reception of the tv stations/channels down to KCPQ-DT 13 FOX. The tv must scan for the Digital Broadcast Tv Channels sometimes called the 'air channels' because the broadcast tv channels travel through the air from the transmitting antenna to the receiving antenna. Do Not scan for cable tv channels.
