Old 10-Feb-2012, 9:02 PM   #1
irbthbow
antenna and preamp suggestions?
here is my report url http://www.tvfool.com/?option=com_wr...0b86ecb50edae5 . I was thinking of a CM 4228HD with a CM7777 preamp. I was planning on putting the antenna about 25' off the ground on the existing DirecTV pole and cutting the cord if I can get some good reception. I had also researched dual antennas a bit and was thinking about that because most of my channel options are in two directions, but not sure that putting 40' apart would work with one preamp. Basically before I install I want to know the best options available to get the most channels OTA. The RG6 would probably be about 80' from antenna to TV. Suggestions?
irbthbow is offline   Reply With Quote
