Old 10-Feb-2012, 12:04 AM   #5
Tv antennas and Tv reception
This recommendation will for sure receive WHPX. Install a AntennaCraft U8000 antenna aimed at about 195 degree magnetic compass. Remove the reflector rods of the U8000 by drilling out the rivets that hold the metal clips that hold the reflector rods. Now the >< shaped metal elements of the U8000 will receive tv stations at the front and back of the antenna. . Also install a Winegard HD9095 antenna aimed at about 111 degree magnetic compass , WHPX. . Combine the two antennas with a UHF channel 26 joiner , from http://www.warenelectronics.com. This set up will likely supply signal to 3 tv's with a simple common 3 way splitter. If a little more push is required to get the signals out to the 3 tv's then install a Antennas Direct CPA-19 preamp at the output of the joiner. . Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com. Buy Ronard from solidsignal or from Ronard. http://www.solidsignal.com , http://www.amazon.com , http://www.antennasdirect.com.
