Old 9-Feb-2012, 11:37 PM   #4
Tv antennas and Tv reception
Ok here is a recommendation for reception of the digital tv stations/channels listed in the current and Pending Applications Included as of 02-07-2012 , down to WHPX-TV 26 ION. , with one antenna. Install a Channel Master CM3000A antenna not less then 25 feet high. WHPX is a very weak station at 1.7 NM(dBm) signal strength and may not be received. The signal strength at 40 feet is 2.1 NM(dBm) , not enough to go to 40 feet for. You can give it a try at 25 feet , if the antenna does do the job you can send it back. . http://www.channelmasterstore.com , http://www.solidsignal.com , http://www.amazon.com
