Old 8-Feb-2012, 1:15 AM   #2
Tower Guy
Originally Posted by KyOTA View Post
I would prefer an attic antenna, again realizing I'm probably at the outside limit for this.
That's right.
For attic mount and both cities, you will want two antennas aimed in different directions. The one aimed at 333 degrees should be VHF/UHF such as the HD7698P. An antenna aimed at 69 degrees can be UHF only. The AP8700 preamp is a good choice, one for each antenna.
