Tv antennas and Tv reception
It is better to use a separate coax system for FM radio. And a separate FM antenna. And when doing coax wiring it is good to install one even two extra runs of coax to each outlet location. The extra coaxes will come in handy later on for routing signals to other locations. The way to wire is , the home run also known as star system. Do not wire with Old loop system method.
