Old 7-Feb-2012, 3:52 PM   #1
briangtbc
Metro Atlanta OTA help needed
Hi everyone. I've recently made the switch to OTA reception only after cutting ties with DirecTV. Saving $700+ a year made the decision a little easier.
TV Fool report: http://www.tvfool.com/?option=com_wr...0b8644cd4e33a6
I've currently installed a homemade Gray-Hoverman antenna in my attic, which is connected directly to a Tivo Premiere with about 75' of RG-6 without any splitters. Before connecting the antenna to my Tivo, I tested it out in my living room by connecting it directly to the TV. I was pleased to find that it picked up 81 "channels" and that was without any real aiming towards the Atlanta transmission towers. Once I installed it in the attic, the number of channels found dropped to 68, but I really only cared about the 4 major networks, PBS and a couple of other local channels that are pretty easy to pick up.
After hooking it up to my Tivo, I'm now picking up even fewer channels and couple of them have very weak signals which cause the picture to flicker, pixelate, jumble, or even drop out entirely at times. Channels 2.1 (39) and 5.1 (27) were most problematic, with neither channel peaking over a value of 55 via the Tivo's signal strength meter. I went up in the attic last night and adjusted the antenna's position so that both 2.1 and 5.1 come in very strong now (5.1 peaking at 80), but now I'm having issues on some of the higher channels like 36.1 (25), 46.1 (19) and 69.1 (43).
I've read on this board and some others about a possible issue with the Tivo Premiere's OTA tuner and/or its issues with multipath. I would assume that's part of my problem since connecting directly to the TV results in less issues with signal fade. I'm curious if another antenna design or something purchased would be better suited based on my geographic location and setup? My single-story house is surrounded by a number of mature hardwoods that are 40'+ (satellite map). I'd prefer to keep the antenna installed in the attic, but I wouldn't be opposed to a smaller-sized roof mount antenna along the lines of the RCA ANT751 if it would help significantly.
Any thoughts or suggestions? Thanks!
briangtbc is offline   Reply With Quote
