Old 7-Feb-2012, 4:18 AM   #6
Tv antennas and Tv reception
WCTE channel 22 is Tennessee PBS , WKYU-DT channel 18 is Kentucky PBS. WCTE is 4.5 NM(dB) stronger of signal strength then WKYU and is in the opposite direction at 135 degree magnetic compass. If you will like to reach out for WCTE , now or at a later date. I recommend install a Winegard HD9095 UHF antenna aimed at about 135 degree magnetic compass. A separate Kitztech amplifier will be connected to the HD9095 antenna , same type of set up. The two antenna systems will be Separate and will not be connected together. Two Separate antenna/amplifier/coax systems will go to the location of the tv and be connected to a Radio Shack # 15-1968 remote control A/B antenna switch , the output of the A/B switch is connected to the tv.
