Old 7-Feb-2012, 1:00 AM   #7
Northshore22
Thank you both for your helpful information and suggestion.
The building has brick wall outside and the window facing west. I hang the leaf antenna on the window facing outside. I set the tv to rescan dtv (Air) only. After the scan, I found the signal strength is better (~68%) and the tv PQ is good. I can receive all the major channels, PBS, CBS, ABC, NBC and FOX. I am happy with the result. Again, thank you both Electron and MisterMe for your help.
Northshore22 is offline   Reply With Quote
