Tv antennas and Tv reception
There are tv channels in both the VHF high band of 7 thru 13 and UHF 14 thru 69. The C2 is a UHF antenna , do not use the C2. She is not using a rabbit ears , she is using a flat panel antenna. It would be correct to say foil backed insulation. Decking is a term that refers to outside porch/pool/entertainment structure or a boat decking and etc. , not the inside of a attic.
