Tv antennas and Tv reception
The Winegard HD7698P antenna is a -> Heavy Duty <-> Long Lasting <-> Long Reception Range <->Outside Roof Top Antenna. The HD7698P antenna Will Be mounted no less then 3 feet above the high point of the roof and higher is better if you choose to get reliable reception of the American channels. I recommend a STRONG and STURDY antenna mount , having 200 dollars plus of antennas fall over because of a weak antenna mount is real close to zero fun.
