Tv antennas and Tv reception
Yes a very good sequence of events , install the ANT751 connected direct to the tv , then install a 4 way splitter and if signal level is to low then install the CM3414. WMYD 21 MyNet is the tv station that has the low signal strength at 7.1 NM(dB) in the list and is the reason for the CM3414 distribution amp. The ANT751 is aimed at WMYD to increase the signal strength. Also the the ANT751 is not a very directional antenna and will receive tv transmissions from other directions.
