Old 5-Feb-2012, 5:48 AM   #2
Electron
Tv antennas and Tv reception
If the house is constructed of wood with wood or vinyl siding and no metal backed insulation then reception of the Canada digital tv stations are easy. Aim a NON Amplified indoor antenna at about 50 degree magnetic compass. Here are two indoor antennas that are NON Amplified , Channel Master CM4010 and Trek HDTVi <-- notice the ( i ) the HDTVi is a NON Amplified indoor antenna , DO NOT buy the HDTVa amplified antenna. Here is how to aim indoor antennas , http://www.kyes.com/antenna/pointing/pointing.html. The indoor antenna must be on ground floor or higher , Not in a basement.
