5-Feb-2012, 4:12 AM
#3
Originally Posted by Electron
This recommendation is based on the current with Pending Applications Included as of 02-04-2012. For the reception of , WUPW , WNWO , WGTE , WBGU , WTVG , WTOL , W38DH , WPDX , WMYD , and what ever else is received. Install a ANT751 aimed at about 40 degree magnetic compass. The the tv stations , WLMB , WUPW , WNWO , are very strong and will overload the AP8700. Install a Channel Master CM3414 Distribution amplifier. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Home Depot may have the ANT751 , here are places to buy antennas and etc . , http://www.channelmasterstore.com , http://www.solidsignal.com, http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com
Thank you very much for taking the time to reply to my post. I will not use the preamp and will return it. I will install a new antenna and connect it directly to my main TV and see what kind of signal I receive. I will then try a 4-way passive splitter and see what effect that has. If I determine there is too much signal loss, I will purchase the distribution amp you suggested.
