Old 4-Feb-2012, 4:53 PM   #1
Northshore22
Please help with antenna
Hi,
The result is here, http://www.tvfool.com/?option=com_wr...0b86ff689fec95
I bought mohu leaft antenna and installed it. I only picked up the channels (62.1, 68.1 not good) in green area. The signal strength is 50 to 65%. The antenna is attached to the wall next to window. I was hoping to get 70% and higher for signal strength in the green area channels. Is it because the antenna not good? What antenna would you recommend? I live in an apartment, I can not install antenna on top of the roof.
Thank you.
Northshore22 is offline   Reply With Quote
