Old 4-Feb-2012, 4:17 AM   #5
Electron
Tv antennas and Tv reception
Still the same , You can also install a HD7084P antenna if you like. Your location has WOI-DT digital channel 5 ABC and it is a weak transmission. This means a antenna with big long metal receiving elements. The HD Stacker does not have the long elements to receive channel 5. All of the tv stations/channels are weak at your location. There is also WOI-DT UHF channel 50 , however it is very weak. A HD7698P antenna can be installed with a CPA-19 preamp. The HD7698P receives channels 7 thru 13 and 14 thru 69 , but not the channels of 2 thru 6. I can not say that WOI channel 50 will have reliable reception all the time. The HD7084P and the HD8200U will receive channel 50 and channel 5. You can try the HD Stacker with a CPA-19 preamp , if it does not receive channel 50 reliably then return it.
