Thread: antenna advice
Old 2-Feb-2012, 11:36 PM   #5
Electron
Tv antennas and Tv reception
Install a Antennas Direct DB4e with Antennas Direct CPA-19 preamp , aimed at about 345 degree magnetic compass , for the reception of , KNWA-DT 50 NBC , KXNW 34 MeTv and Retro tv Network , K62DQ 41 CBS and MyTv Network , KEGW-LP 30 MyTv Network , KWNL-CD 31 Univision , KFFS-CA36 This Tv , KWOG-DT 39 IND. . Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Mount the DB4e just above the roof. The reason just above the roof , your reception location , the higher the antenna is , the weaker the weak stations become , this is an effect that some times happens when tv signals are bent a little when traveling over hills and low mountains. The bending effect concentrates the tv signals lower to the ground.
