Tv antennas and Tv reception
The receivable network channels are of 3 different directions and most are weak signal strength. One way to receive the tv stations is to use a rotor , antenna rotors are not friendly for channel surfing , must wait for the rotor to turn the antenna to the station you want to surf. And antenna rotor will not be friendly for two or more tv's connected because there will be disagreement about where the antenna is pointed. I am evaluating the situation to combine more then one antenna for simple reception and channel surfing.
