Old 2-Feb-2012, 8:03 PM   #6
Electron
Tv antennas and Tv reception
For reliable reception of , KFMB-TV 8 CBS and KGTV-DT 10 ABC at 169 degree magnetic compass , install a Winegard YA1713 antenna with a Antennas direct CPA-19 preamp aimed at about 169 degree magnetic compass. Install the antenna at about 25 feet above ground. The antenna can be installed above the HD7698P antenna with about 3 feet separation. The two antenna systems will not be connected on to the same coax. The two antenna systems will have separate coax that goes to the location of the tv and the separate coaxes of the two antenna systems will be connected to a Radio Shack #15-1968 remote control A/B antenna switch and the output of the A/B antenna switch will be connected to the tv.
