Tv antennas and Tv reception
I recommend the DB4e because it has a wide forward beam width , forward beam width is the angle to the right and left sides of the front of the antenna that the antenna will receive tv stations. At your location WVIR-DT 32 NBC and the group of stations at 51 degree magnetic compass are widely spaced apart , so aim the DB4e between the stations and receive in both directions. The 91XG has a very narrow beam width. The antennas and hardware I recommended will receive the most tv stations with the fewest antennas.
