Tv antennas and Tv reception
Some thoughts , The tv needs to scan for the , Digital Broadcast Tv Channels , also known as the 'Air Channels'. Do not scan for digital cable tv channels , Do not scan for analog cable channels. . Also look inside the connectors on the ends of the RG-6 quad coax , if the foil shields and shield wires are pushed in toward the center conductor , push the foil shields and shield wires away from the center conductor.
