I assume that you are trying to get WAFF RF-49 in Huntsville, AL and not WSMV RF-10 in Nashville, TN. Weak transmission is not the problem. Your problem is that weak signal at your antenna. As you no doubt know, Huntsville is located in the Tennessee River Valley and there is also a mountain between you and the city. This partially explains why all of the Huntsville stations are 2Edge. WAFF also suffers from co-channel interference. The first thing that jumps out at me is that you have your antenna elevated to 16 feet. Redo your TV Fool Radar plot for 20 feet and 30 feet. I am confident that your reception will dramatically improve on all Huntsville stations if you raise your antenna.
