Old 31-Jan-2012, 10:40 PM   #1
saline
Choosing a indoor antenna
Condo indoor antenna advice needed
Hi everyone,
I live in a building on the 7th floor with no line of sight (facing North) and boxed in by 2 extension of the building from the East/West and even a little bit from the North. The building has no balcony so I'm stuck with using the antenna indoor.
Have tried using the Terk HDTVa (8-12 channels), rabbit ears with amp (5-12 channels) but having limited success as some channels would cut off quite often and I have to move the directional antennas to get different sets of channels. Have also tried the omni-directional antenna Channel Master 3000A which only got me 2 channels.
Looking to get the following channels consistently without moving the antenna VHF CH 9, UHF 41, 47, 53 and maybe 64.
Would the winegard FV-HD30 or the Antenna Direct DB2 help in my situation? What type of antenna do you guys recommend for my situation or am I stuck with cable?
Here is my report from TV fools
http://www.tvfool.com/?option=com_wr...0b868554d4931a
Any advice is appreciated
Thanks in advance!
Last edited by GroundUrMast; 1-Feb-2012 at 3:58 PM. Reason: repaired broken TVFR link
saline is offline   Reply With Quote
