Electron
Hi Electron, Thank you for your help so far. Does the signal map given take into account terrain? I know I am below the escartment in Hamilton which is about 150' tall I think. I am a fair distance from it. My map says I can receive the Buffalo stations and you mentioned with the larger antenna I should. Is this a fair assumption? I will go out and purchase if it is. I would love to get some USA stations from the New York area. The larger unit you recommended can I purchase a rotator for it that turns and has a memory that will stop at certain areas if pre-set? I am so excited this works I will be a follower of this site and tell everyone about it. THANKS!
