Old 31-Jan-2012, 6:02 PM   #2
Tv antennas and Tv reception
This recommendation is based on tvfool radar report of Pending Applications Included of digital channels as of 01-31-2012. Install a ANT751 antenna aimed at tv station WHTM at about 345 degree magnetic compass. The ANT751 is not a very directional antenna and will receive the tv stations/channels in the green and yellow zone. The tv transmissions are strong at your location and the ANT751 should provide signal to 1 to 4 tv's . . 'If' WITF-DT 36 PBS is weak when a 4 way splitter is used then replace the 4 way splitter with a Channel Master CM3414 distribution amplifier. For 5 or more tv's connected , use a CM3418 distribution amplifier. Here is how to aim antennas and etc. , http://www.kyes.com/antenna/pointing/pointing.html. Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com. Here are some above roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
