Old 31-Jan-2012, 7:59 AM   #25
ghz24
perhaps even model it
Don't take statements of performance wrong most of the statements are comparing it to a non-fractalized (if that's a word) similar antenna.
You seem very interested in the characteristics of this antenna so why don't you take the leap and download 4nec2 (free modeling program)
and give it a shot. (it's not that hard if you have an already built model)
Here is the antenna you made with no reflectors (gain is dBi net) UHF
Code:
max	7.0452717189		7.8089515597
min	4.6449004552		2.3223250366
Average	6.3864243396		3.8669560812
I'm kind of surprised you get a usable digital signal at all, SWR over ~2.7 can kill a digital signal.
with a flat reflector it's better. edit:changed gain figures to match the corrected model
Code:
max	10.9458221554		4.4905919223
min	8.9146671202		1.6696213956
Average	10.2025694137		2.3975494407
and if you do try the modeling program here's the model I used to get the figures above to get you started.
Code:
CM Ruckman Fractal 2 bay bowtie
CM by GHz 24
CM AWG Gauge 12 Copper Wire Elements
CE
SY z=5.25
SY y=0.625
SY x=-5.5
GW	1	3	0	y	0	0	y	z	0.0404
GW	2	3	0	y	z	0	4.09807087-1.5+y	1.5+z	0.0404
GW	3	3	0	4.09807087-1.5+y	1.5+z	0	4.09807087-1.5+y	4.5+z	0.0404
GW	4	3	0	4.09807087-1.5+y	4.5+z	0	6.69615354-1.5+y	3+z	0.0404
GW	5	3	0	6.69615354-1.5+y	3+z	0	9.29422441-1.5+y	4.5+z	0.0404
GW	6	3	0	y	z	0	4.09807087-1.5+y	4.5+z-6	0.0404
GW	7	3	0	4.09807087-1.5+y	4.5+z-6	0	4.09807087-1.5+y	1.5+z-6	0.0404
GW	8	3	0	4.09807087-1.5+y	1.5+z-6	0	6.69615354-1.5+y	3+z-6	0.0404
GW	9	3	0	6.69615354-1.5+y	3+z-6	0	9.29422441-1.5+y	1.5+z-6	0.0404
GW	10	6	x	0	2	x	12	2	0.0404
GW	11	6	x	0	4	x	12	4	0.0404
GW	12	6	x	0	6	x	12	6	0.0404
GW	13	6	x	0	8	x	12	8	0.0404
GW	14	6	x	0	10	x	12	10	0.0404
GW	15	6	x	0	12	x	12	12	0.0404
GX	400	011
GW	16	12	x	-12	0	x	12	0	0.0404
GW	37	3	0	y	0	0	-y	0	0.0404
GS	0	0	0.0254		' All in in.
GE	0
EK
LD	5	0	0	0	5.8e7	0
EX	0	37	2	0	1	0
GN	-1
FR	0	1	0	0	585	0
EN
just copy and paste into a text file and save as "fractalblabla.nec"
then open it with 4nec2. The variables change the gap,separation,reflector distance.
If you get stuck you could open a thread in the antenna section or enthusiast exchange area.
Rather than discuss design in the help with reception area.
ghz24 is offline   Reply With Quote
