Thread: CM-4228HD Alma
Old 31-Jan-2012, 6:57 AM   #2
The CM-4228HD is a UHF antenna, for real channel 14 and higher. You need an antenna that is also able to receive VHF channels (2 through 13).
The 14 db Nexxtech amplifier is enough, you do not need any more amplifiers.
Most of your signals are VHF, consider adding a Winegard HD5030 aimed at 83°.
