Thread: CM-4228HD Alma
Old 31-Jan-2012, 12:55 AM   #1
Alma
CM-4228HD Alma
http://www.tvfool.com/?option=com_wr...0b860d4ff7ab98
CM-4228HD on 10 ft mast on Eave Mount (appr. 25 ft from floor)
Appr. 20 ft RG-6 satellite cable to split: fm tap and 14 db Nexxtech one-way professional broadband signal amplifier. Output to split 2 tv. Fm tap split 2 radio.
Ch. 13 good at 80% minimum, drop often to 0
Ch. 12 good at 90% minimum, drop less often to 0
Ch. 8 good between azimuth 83 and 108 near 100%
Ch. 6 good at 40% minimum
Antenna more near azimuth 83 than 108. (Ch. 6 can reach 55% at 108 deg)
Ch. 13 can reach 85% at azimuth 83
Ch. 12 can reach 95% at azimuth 83
I place an order to install CHANNEL MASTER CM 7778 TITAN2 VHF/UHF PREAMPLIFIER
*****Is it a good guess ?
Can you please make recommandation ?
Thanks a lot and regards,
Pascal
Alma is offline   Reply With Quote
