Old 30-Jan-2012, 4:59 AM   #5
Electron
Tv antennas and Tv reception
If you will like to receive more channels now or at a later date. Then install a Winegard YA1713 aimed at about 302 degree magnetic compass to receive WSET-TV channel 13 , The Retro Tv Network and ABC. . Also install a Winegard HD-9032 aimed at about 182 degree magnetic compass for the reception of WRPX-DT channel 15 ION Television , WRAY-DT channel 42 IND. , WUNP-Tv 36 PBS. . Connect the YA1713 and the HD-9032 together with a , UVSJ = UHF-VHF-Separator-Joiner. A Antennas Direct CPA-19 will be connected to the output of the UVSJ. The YA1713 and HD9032 and UVSJ and CPA-19 , make up a complete antenna system that has a coax that goes to the location of the tv. This antenna system Is Not connected to the DB4e antenna coax , the DB4e and CPA-19 preamp are a separate coax that goes to the location of the tv. At the location of the tv a , Radio Shack # 15-1968 , remote control A/B antenna switch will select one antenna system or the other. Here are place to buy antennas and etc. , http://www.radioshack.com , http://www.winegarddirect.com , http://www.amazon.com.
