Your proximity to the shadowing hill suggests that channels 8 & 10 are going to require more effort than your TVFool plot would suggest. You're going to need more than a small, mis-aimed antenna at your location. You may need to resort to amplifying the VHF (only) signal. Ugh! I can't believe I actually suggested that.
Go with the high-gain high-VHF antenna pointed at La Jolla and a separate small UHF aimed to split coverage between Tijuana and Mt Miguel.
Combine the antennas with the UVSJ as suggested.
