Old 7-Jul-2010, 9:09 AM   #1
gallwapa
Help selecting antenna, options?
http://www.tvfool.com/?option=com_wr...9fbe2ea0e4372c
I currently use cable and haven't used antenna's before. I have newly run RG6 runs from a wiring closet to my television. Currently, I have 1 splitter in place (though I would like to hook up cable modem, HTPC, and 2 TV's. Currently I have cable modem and HTPC hooked up. The HTPC contains a hauppauge 2250, which contains a built-in splitter)
I'd like to get ABC, NBC, CBS, PBS, CW, and FOX. Optional but desired channel would be KONG then anything else goes.
With cable, I'm sick of my bill, and I'm sick of drops on cable (Comcast has been out and re-run my drop, re terminated the wires in the house which were factory installed, then replaced the wires themselves). Money is limited, so at this point if I can simply replace cable that would be great, then adding anything necessary to put the additional TV tuners online would be fantastic.
My attic space is limited in height, only providing crawling space.
Here is a photosynth of my back yard to view obstructions nearby (trees, etc)
The house is South and the TV stations are North (approximately). The large tree to the south has been cut down.
Thanks for all your help!
gallwapa is offline   Reply With Quote
