Old 26-Jan-2012, 2:34 PM   #9
Electron
Tv antennas and Tv reception
Indoor rabbit ear type antennas are two directional antennas , http://www.kyes.com/antenna/pointing/pointing.html. Aiming one side or the other of a rabbit ear type antenna at about 14 degree magnetic compass will position the rabbit ear type to receive the greatest number of stations to the , north west , north east . south east and south west. When the rabbit ear antenna is aimed at 14 degree magnetic compass , the rabbit ear type antenna is all so aimed at about 202 degree magnetic compass. Put a popcicle stick on the radar map , and the length of popcicle stick is the rods of a rabbit ear type indoor antenna. Either end of the popcicle stick is the part of the antenna antenna with the least reception. Now turn the popcicle stick around like a compass and see what direction produces greatest number of tv stations to receive. And this is also a balancing act of the strongest tv stations and the angle of reception and the weaker tv stations and the angle of reception. The greater the angle of reception off to the sides of the two directions of the rabbit ear type antenna the less reception will take place. So it is best to put the stronger stations at more of a angle and the weaker stations at less of a angle. . The ANT751 is a small antenna that works Very Much Like a indoor rabbit ear type antenna , so the same applies.
