Thread: Antenna Advice
Old 26-Jan-2012, 3:14 AM   #9
Cable TV is designed as a closed system. This means that the signals inside the shielded cable can and do use frequencies assigned to aircraft navigation and communications services as well as other life safety services and licensed point to point and mobile systems.
If you connect an antenna to the cable TV system, you will very likely cause harmful interference to over-the-air radio services. Even if the only service delivered to your home is internet, you need to be certain you are not connecting active cable system signals to your antenna.
However, you can disconnect the coax cable from the cable TV network and use the coax to distribute your antennas signal to your TV(s).
