Tv antennas and Tv reception
The coax 'cable' wires can be used to get the tv antennas signals from point A to point B , ( from the box to the rooms in the house ). However the antenna Can Not be connected to Any Type or Kind of Active cable tv service. Not active cable tv service , Not active cable phone service , Not active cable internet service , Or any other type or kind of active cable delivered service. If a coax cable is needed for , as a example , cable internet service. Then a coax cable will need to be installed to get the antenna signal from point A to point B. If as an example , there is no type or kind of cable service being delivered to the house. Then the coax cable that delivers cable service to the house can be disconnected from the coax wires of the house and the antenna can be connected to any or all of the coax wires of the house.
