Old 6-Jul-2010, 9:30 PM   #8
Dave Loudin
Originally Posted by Thinkup View Post
So what I'm looking for is a directional VHF antenna that fill fit in my attic that will give me both low and hi VHF signals then? Is that correct? Is it even worth trying considering the hills around me?
No, you need a VHF/UHF antenna (look at the Real channel column). I was trying to second-guess what you meant about what to skip for a smaller antenna. Elements for VHF reception are much larger than those for UHF. TVFool has already considered the hills for you as far as reception goes at your house. If you are asking about putting an antenna on one of those hills, then use the "start MAPS" option to move the receive location marker to the right spot.
