Tv antennas and Tv reception
Those tv stations are deep in the gray zone with NM(dB) numbers in the negative 20's , reception will not happen. . You can enter in higher antenna heights and see if the NM(dB) numbers can be raised to positive 10 NM(dB) or better. And you will need a Big antenna , a Winegard HD8200U or a Channel Master 3671.
