Thread: Antenna Advice
Old 25-Jan-2012, 4:49 AM   #4
Electron
Tv antennas and Tv reception
For reception of , NBC , METV , CBS , CW , ABC , This Tv , Fox , MyNetwork , PBS , and many more Tv stations/channels and digital sub channels. Install a AntennaCraft U8000 antenna above the roof , aimed at about 334 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. The U8000 will need to be made into a antenna that will receive tv transmissions at the front and back of the antenna , this is easy to do , drill out the rivets that hold the flat metal clips that hold the reflector rods , remove the reflector rods , Now the U8000 >< shaped metal reception elements will receive 2 directions , the front and back of the antenna. For 4 tv's connected , use a Channel Master CM3414 - 4 way distribution amplifier. For 5 to 8 tv's connected use a CM3418 distribution amplifier. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html. Here are places to buy antennas and etc. , http://www.antennacraft.net , http://www.channelmasterstore.com , http://www.solidsignal.com , http://www.amazon.com
