I'm new at this and it is an exciting challenge. I got to thinking about Electron's reply that I would have to use two different systems with two lines using an A/B switch. Would a combiner work with the UHF antenna from the NW connected to the UHF terminal of the combiner and then I would be connecting the other antenna cable to the VHFterminal that has to carry VHF and UHF signals. Will it work?
