You have two major groupings of stations, one to the NE and the other to the SE.
If you can locate the HDTVi so it has a view through a window while aimed at the stations of interest, you'll probably do well. On the other hand, an indoor antenna shielded by the foil and wire mesh will have a tough time.
Are you willing to consider a small outdoor antenna system? You would not need a large deep fringe antenna, there's plenty of easy to receive signals available to you. I'm thinking something on the order of the Antennas Direct CS2-V
Reason: link for CS2-V
