Thank you for the reply. Two story house with a finished room over the garage and a attic access. Outside is brick in the front with vinyl siding on the other walls. Asphalt shingles on roof. Currently using RCA rabbit ears and can pick up around 15 channels on my main TV. I have cable hookups in 5 rooms with a cable box outside. Would like to install something in the attic if possible. Area is very flat as its eastern NC.
