Tv antennas and Tv reception
The wording of your response has me thinking that you do not understand. This is 2 separate antenna systems. The HD7082P aimed at 35 degree magnetic compass with the CM3414 distribution amp. is one system. . The DB4e UHF antenna with the AP8275 preamp. aimed at 311 degree magnetic compass is a second separate system. The 2 systems are not connected together on to one coax. No antenna rotor is used at all with either antenna.
