The signal from WCYB calls for an all channel antenna design. Few television markets have stations on the low VHF channels, in large part due to a bit more noise and interference in that frequency range. The signal from WCYB is strong enough at your location to expect little or no trouble with reliable reception.
The HD Stacker does not have elements tuned for reception of real channels 2 through 6.
The HD9032 is a UHF only design.
I'd recommend a Winegard HD7082 aimed at 45° compass.
Which model preamp do you have? Chromstar 2000 is the name of a series of preamps, some of which may be less than ideal for your application.
A PBS signal comes from the NW so a rotator or second antenna may be needed. How many sets will you connect to this antenna system? The answer to this question may drive the choice between a rotator or an alternate suggestion.
