Just a suggestion
Most all band antennas have higher gain and narrower beam in the UHF and lower gain and wider beam on VHF.
So miss aiming the antenna a little (while you're doing your channel scan) may hurt the UHF signal more than the VHF signal. That may make the TV pick the VHF and not see the UHF.
After you scan you should be able to re-aim for best all around reception.
Another ides is most TVs scan up and 50 is near the top so when the scan is almost complete pull the antenna connection so when presumably it is looking for a station at channel 50 it wont see anything.
Try the second one first (you can stay in the warm if that works and saves two trips too the roof)
Have to wait for 48 though.
