Thread: Antenna Advice
Old 20-Jan-2012, 4:04 AM   #7
Dave Loudin
This is a tough call, as you want to distribute to multiple TVs. I don't see a good way to reliably get the channels you want with a single antenna and there is no good way to combine the two into a single feed. Your db2 should work for the 286 group. For the stations to the north-northeast you need a high gain hi-VHF/UHF antenna like an AntennaCraft HBU-55 or a Winegard HD-7698P. Since both antennas receive UHF, you can't combine them.
You may need to decide which TVs see which antenna. I know @GroundUrMast has some thoughts using computer-attached tuners.
