Tv antennas and Tv reception
Not giving an exact address increases the posibilty of not getting a accurate picture of the reception situation. I recommended the HD7694P because the Tv stations to the north and north west are widely spaced , The HD7694P antenna has a wide beam width , the angle the antenna will receive off of front center. Yes use the preamp. Solid copper center coax is better then copper covered steel , However use the coax you have.
