Rapid fluctuation of the signal meter reading makes me think of a few possible causes:
1) Multipath - Try moving the antenna, outdoors in the clear is almost always the best place.
2) A poor connection between the coax shield and coax connector shell - Inspect all connections carefully.
3) Signal reflection from an unterminated splitter port - Avoid using a splitter with more ports than needed, use 75Ω F-Termination resistor caps on all unused ports.
4) Interference from FM station(s) or other sources such as computers, appliances, power tools, etc. - An inline FM trap is not too expensive. It's a bit of a stretch, but WDAF FM 106.5 is 1/6th the frequency of UHF CH-42. Turn off powered equipment to see if the trouble changes or goes away. Move the antenna away from sources of interference.
