Old 19-Jan-2012, 7:16 AM   #19
Comparison of 1/4 vs 5/8 radiation patterns
Here is a 3D model view of the radiation patterns of the common 1/4 wave whip compared to the theoretical radiation pattern of a 5/8 wavelength base loaded whip.
Both are simulated over perfect ground... which your fender will is not.
Here is the 4NEC2 code for the 5/8 WL model:
CM Base loaded 5/8 wave vertical whip antenna over a perfect ground plane
CE
SY WR=#14
SY DEL=1.868521 'Element Section Length in Meters
SY COIL=6.125e-7 'Load Inductance, Henrys
GW 1 30 0 0 0 0 0 DEL WR
GE 1
LD 5 0 0 0 1390000 'Stainless Steel
LD 0 1 2 2 0 COIL
GN 1
EK
EX 0 1 1 0 1 0 0
FR 0 0 0 0 100 0
RP 0 285 73 1510 90 0 5 5 0 0
EN
Here is the 4NEC2 code for the 1/4 WL model:
CM Simple quarter wave vertical whip antenna over a perfect ground plane
CE
SY WR=#14
SY DEL=0.755 'Element length in Meters
GW 1 17 0 0 0 0 0 DEL WR
GE 1
GN 1
EK
EX 0 1 1 0 1 0 0
FR 0 0 0 0 100 0
EN
File Type: pdf FM Whip qrtr vs five eigths patterns.pdf (363.9 KB, 4075 views)
