Thread: New to OTA
Old 19-Jan-2012, 6:29 AM   #4
Electron
Tv antennas and Tv reception
The American and Canada Tv stations transmit both Analog and Digital tv transmissions. Your location has no receivable Analog tv transmissions from America. Your location does have receivable Analog and Digital tv transmissions in Canada. Also like the USA , Canada is transmitting tv in all 3 tv bands of channels , VHF low channels 2 thru 6 , VHF high channels 7 thru 13 and UHF 14 thru 69. The tvfool list of Canada stations/channels is not up to date and might not list all or correct of the Canada tv stations/channels on the air. To receive all of the Canada channels that can be received both Analog and Digital , and of all 3 tv bands , Install a Channel Master , MASTERPIECE 5016 antenna with a Winegard AP8700 preamp aimed at about 120 degree magnetic compass. . The 2 antenna systems One for America and One for Canada. Will Not be connected together on to one coax at the same time. The two antenna systems will be separate to the location of tv and or tuning devices. A remote control A/B antenna switch can be used to select one antenna or the other. http://www.saveandreplay.com.
