Old 18-Jan-2012, 12:15 AM   #5
razmichael
Question on the HDHR3-US you mentioned. I recall you noted in another post (where you provided a diagram on your hookup using multiple HDHRs that this new model only has one antenna connector (and I checked the website/documentation). I'm thinking it might make sense to pick up a used older model (they seem to run around $60). From the FAQ entry on the product site and your description, you can then use the two separate antennas with the two tuners (assuming the PC software allows this). This would not let you watch one channel and record another unless the sources where from each antenna but this would be a minor inconvenience.
razmichael is offline   Reply With Quote
